autoscale only upper bound
Is there a way to autoscale only the upper bound of the Y axis on the XY graph.  I would like the lower bound to be fixed at zero.  I'm using LabView 9.0
      Thanks, Vitaliy
(2,758 Views)
Accepted by topic author vziskin
I don't think you can do auto-scale this way, but you can change the axis setting though a vi.  You can change your y axis max to the max of your y values + an offset.
Yik
Kudos and Accepted as Solution are welcome!
(2,733 Views)
