Writing to XML within loop
I am able to write datas to XML file. But when I am writing inside loop then for second loop it is generating issue and giving error. attached VI which will update for single run successfully. Let me know where is issue
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 9
(5,451 Views)
This VI works, but in single run and if placed in a loop, so i can't reproduce your issue. Do you manage to close the XML ref in the loop?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(5,431 Views)
Ok take this VI which I wrote for writing in loop.
--Ranjeet
Message 3 of 9
(5,420 Views)
If you unravel the loop you'll notice it's the 2nd Testdata that's causing the error.
/Y
Qestit Systems
Message 4 of 9
(5,412 Views)
If you unwrap the loop you'll notice it's the 2nd Testdata that's causing the error.
/Y
Qestit Systems
Message 5 of 9
(5,412 Views)
I guess where tag is boxno where issue is coming. Let me know how to resolve it
--Ranjeet
Message 6 of 9
(5,408 Views)
The problem is your XML tree structure, you must have a single root element. Create a TestSession element before the for loop and the last thing to do in this loop is to append the TestData node to this element. After the loop you append the TestSession element to the document.
Ben64
Message 7 of 9
(5,341 Views)
Ben64
Note that the TestSession node can be appended to the document immediatly after its creation, which is probably better. Then you just close its reference after the loop.
Ben64
Message 8 of 9
(5,305 Views)
XML is an interesting format -- it is "human-readable", seems to "map" reasonably well with LabVIEW data types (various representations of numbers, booleans, strings, paths, arrays, clusters), and there are several (at least 4, I think) implementations of it available for LabVIEW.
What's also interesting is that (possibly because of its "open" nature) there is no set way that XML is generated and parsed, and the resulting file formats are often not compatible with each other.  This need not be an issue if you are doing the reading and writing, but can make it a little less "portable".
Another interesting thing that I've noticed is that the "model" of how (several) XML systems seem to work is that the file is open, a single Write of "Everything" is done, and the file is closed, with Reading/parsing largely the inverse of this.  In particular, the notion of opening a file and "streaming" data in XML format as it is being generated does not seem to "fit" the usual model.
Fortunately, with at least two XML packages (EasyXML from JKI Software, and NI-GXML, from the LabVIEW Tools Network), it is possible to "extend" this model and to allow for such streaming.  In addition, both packages allow a very "intuitive" way to write and read/parse XML in flexible ways.  I'm less familiar with the version of XML that ships with LabVIEW, and haven't looked carefully at LabXML.
Bob Schor
Message 9 of 9
(5,291 Views)
