Writing to a data file with time stamp - Help!
I ran the program and it has an error when it reaches 12:00 am. IT says the file " todays date" does not exist.?
Message 11 of 39
(1,512 Views)
This is the error I get?
Message 12 of 39
(1,509 Views)
Hi
Please find attached Vi useful 🙂
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 13 of 39
(1,501 Views)
Ian,
How do I integrate this into my existing program. Should I group my write file in the while loop or what...sort of confusing. Can you show me with my existing program.
Message 14 of 39
(1,492 Views)
In the small case statement inside the while loop, I forgot to set the functon for Open/Create/Replace File to Create or Replace. It defaults to Open only so when it is time to create a new file, the error will appear.
Message 15 of 39
(1,482 Views)
Dennis,
I have already figured that out and made a constant for the open/replace vi. But unfortantely the original file keeps logging. I'm not sure why but the original one never closes. Any other suggestions. I have tried to put a close file in the case structure if the time = 12Am. let me know..
Message 16 of 39
(1,470 Views)
hi PierT,
I have integrated it into your VI without removing the original file IO functions.
You might, still, need to further polishing it 🙂
Cheers!
Ian F
依恩与LabVIEW
Message 17 of 39
(1,435 Views)
Ian,
Thanks for the help. I ended up doing it a different way but I guess either one will work. Attached is what I came up with.
One question I have is if there is a way for my program to have a delay before writing data to a .csv file after my trigger goes high and to stop the writing before the trigger turns off.
To specify more I have a trigger which tells my program to start logging data. Now my device takes 5 seconds to get a good reading so I have to start after 5 sec. And then when it turns off it takes about 5 seconds again. Any suggestions would be great. My trigger by the ways is 7sec on 2 seconds off.
Should I use shift registers? not sure?
Message 18 of 39
(1,427 Views)
Hi Pier,
I am not quite sure if I understand your problem faced as quoted. Nevertheless, please have a look at the attached VI. I have included, to the VI, a 5000ms timer, which starts timing when the Channel Data >= HighLevel Trigger. In this case, this next Channel Data which exceeds the HighLevel Trigger level will take effect only after the file save.
Hope this is clear 😛
Cheers!
Ian F
依恩与LabVIEW
Message 19 of 39
(1,403 Views)
If I need to take an average of the values that I read from my channels and take out any high readings and then write them out to a file, can i do that in a seperate case statement within the main?
Message 20 of 39
(1,397 Views)
