Writing to a holding register _ Tension controller MODBUS
Here I come again.
I have been trying to write a certain value in a register but it's not working.
Attached you can find the manual.
On page 4 it says I should write on register 142.
Perhaps I am setting it wrongly in Labview. First I read the value (register 296) after I try to write a different value but it does not work.
Thank you.
Message 1 of 17
(1,426 Views)
Writing 2 registers (142 and 143) mean you should use an array of only 2 elements.
Starting address = 142
Holding register values = [0,0]
Currently, you're writing an array of 143 elements of value 0.
Message 2 of 17
(1,423 Views)
Hi PinguX,
I have changed it and still the value in the device remains the same. I have tried to write a setpoint value of 0 [0,0].
Message 3 of 17
(1,382 Views)
Hi Henk,
Where do you try that?
The array control in your image shows an empty array…
Message 4 of 17
(1,380 Views)
I have been trying to write a value of 0 to the setpoint as a test. I tried 2 columns array and two rows array. No change in the device.
Message 5 of 17
(1,373 Views)
Hi Henk,
A 1D array has no "columns" or "rows", it only has "elements". (Rows or columns are just display cosmetics!)
@henk1000 wrote:
I have been trying to write a value of 0 to the setpoint as a test. … No change in the device.
Do you get any error from ModbusWrite function?
Is the value 0 allowed for that register?
Which data format does your device expect for the value in those 2 registers? Does it expect a SGL float value or an U32 integer value?
Message 6 of 17
(1,367 Views)
No error from the device.
The device allows 0 value.
U32 float I guess.
Message 7 of 17
(1,359 Views)
Hi Henk,
@henk1000 wrote:
U32 float I guess.
There is no "U32 float" - and there is no need to guess!
The manual clearly says "float", which is a SGL in LabVIEW!
Yesterday I explained TO YOU how to convert two U16 values into a SGL value, now you fail in converting a SGL value into two U16 values?
Message 8 of 17
(1,348 Views)
Well, 0 SGL 00000000 00000000 00000000 00000000
two U16 : high 00000000 00000000
                low   00000000 00000000
0 should be 0 right?
Message 9 of 17
(1,338 Views)
Hi Henk,
Yes, in this very specific case you are right.
But in any other case you are not - despite explaining the concept just yesterday…
Do you have other software where you can verify your device does accept the zero value for this register?
Message 10 of 17
(1,334 Views)
