Writing to a holding register _ Tension controller MODBUS
I've tried writing the register using python but it did not work. The manual talks about writing to the memory but I do not fully understand it..., how I am supposed to use the blocks in Labview and writing in the memory of the device.
Message 11 of 17
(809 Views)
Hi Henk,
At first: You should ask the manufacturer when you have questions on their manual…
My interpretation of the shown text snippet: you need to write certain values to a command register (@320) to have your device actually use the changed values in the parameter registers…
Message 12 of 17
(805 Views)
I have sent them email early when I arrived at work. Still waiting for a reply.
I will  write a single register to @320 and after try to write to @142, 143 and see if it works.
Message 13 of 17
(800 Views)
Did not work 😑
Message 14 of 17
(784 Views)
How is the controller connect to your PC ?
Can you share your test vi with us?
Message 15 of 17
(767 Views)
Computer -> switch (static address) -> device
For reading it works now. The main problem is to write. I am now trying with python for writing the values in the register.
Message 16 of 17
(763 Views)
Accepted by topic author henk1000
So far the solution is using a python script.
Message 17 of 17
(733 Views)
