Writing to a serial EEPROM Atmel 24C04 in Labview 6.0.1
Has anyone written a vi to communicate with a serial EEPROM? I checked Atmel
site for a sampel but no luck.
Jamie
(4,537 Views)
"James Dorsey" wrote in message
news:3a8d35f6@newsgroups.ni.com...
Atmel
> Jamie
Hi Jamie
The Xicor XDCP Test Utility might give you some ideas and is available free
from http://www.xicor.com/form_download.html. Although it is aimed at their
digital pots; it should be adapatable to other I2C devices.
Regards
Keith
(4,537 Views)
yeah, I used an atmel part with SPI hanging off the parrallel port. works
ok, kinda slow if you want to max out the SPI channel, but pletty fast to
test functionality. If you want SPI code, I can see what I can dig up, let
me know...
Thomas Kreider
tkreider@uswest.net
Keith Fuller wrote in message
news:3a8d4875@newsgroups.ni.com...
> Atmel
> > Jamie
> Hi Jamie
free
aimed at
their
> Regards
> Keith
(4,537 Views)
I've used an I2C interace that plugs into you're serial port and is made by
http://www.mcc-us.com/. MIIC-202 is the device I used and I believe it
costs around $200. The serial port commands required to interface with it
were very easy to program in LabVIEW. If you end up using this device let
me know and I can send you what I've done to help get you started.
Best Regards,
Neal Pederson, President, VI Control Systems
1923 Mendius Lane, Los Alamos, NM 87544
TEL: (505) 662-1461, FAX: (603) 388-4969
np@vicontrols.com, www.vicontrols.com
James Dorsey wrote in message
Atmel
> Jamie
(4,537 Views)
