labview 6 application builder problem
I' creating a application.exe with Application Builder.
I'open application, automatically running the Labview run time and appare
the message 'is not a vi'.
Really is a application.exe and not a vi.
Why does it happen ?
I hope my English is good enough so you can understand what I wrote
thank in advance to any one that will answer this add!
Pradipaldo
(3,396 Views)
Try saving you top level VI with all the VI hierarchy into VI library (*.llb) and then launch the Application builder, select your top level VI from the LLB and proceed. Hope this would help.
Abdullah
(3,396 Views)
It may be that you have not selected a top-level VI for your application. The LabVIEW 6i Application Builder can include all of your (non-dynamically loaded) subVIs for you automatically, just based on telling it what your top-level VI is. I thought the Application Builder would check for that automatically, but apparently it doesn't.
For help with the Application Builder, I recommend the LabVIEW Application Builder Troubleshooting Wizard in the National Instruments Support site. You can get there by going to http://www.ni.com/support and then choosing "LabVIEW" from the list of products. That will take you to the main LabVIEW Support page (http://www.ni.com/support/lvsupp.htm). From there, choose the link to the "Application Builder Troubleshooting Wizard". That p
age has version-specific Application Builder help for LabVIEW 5.0, 5.1, and 6.0.
Mr. KB
(3,396 Views)
I think I partly understand your problem. You're intending to create an
application, therefore you use
the AB to do the job. Could you make things clearer? What is the application
you are working with? Maybe this would
give us more information so that we can help you.
FZ
tin wrote in message
news:eUDi6.4434$Uj1.124260@twister2.tin.it...
> Pradipaldo
(3,396 Views)
