Writing to an Excel Template without showing
Hi all..
Please have a look at the attached VI. (LV7.1)
I have tried to open n existing template and write some data at particular cells. I dont want the Excel to open up and show.... it should automatically write.
Message Edited by Nghtcrwlr on 07-22-2009 04:49 AM
Nghtcwrlr
Message 1 of 15
(4,870 Views)
HI
I think the best way to do this you can use "MS office Report" express vi.
Hope this helps
Regards
Santosh
Message 2 of 15
(4,865 Views)
Hi Nghtcrwlr,
see the attached picture. It should work for you.
Mike
Message 3 of 15
(4,862 Views)
Hi ..
I tried to solve that problem. But now 2 errors comes up. One is attached below. and the other is LV crashes suddenly... any idea???
Nghtcwrlr
Message 4 of 15
(4,855 Views)
Hi Nghtcrwl,
you got this message, because you never close the document and excel. Why didn't you try it like shown in the picture before?
Mike
Message 5 of 15
(4,842 Views)
Sryy.. i didnt notice ur message before posting. I tried with what u mentioned. See the attchment. But now i cant open the Excel in a normal way . When i open it from the folder, it jus appears for a second in the screen and goes off... why is it so?
Nghtcwrlr
Message 6 of 15
(4,828 Views)
it's because of the close methods at the end. If you want to edit the file manually, then you have to disable them.
Mike
Message 7 of 15
(4,822 Views)
Hi Mike..
i removed both close methods at the end. STill its not wrking.
Nghtcwrlr
Message 8 of 15
(4,817 Views)
Accepted by Nghtcrwlr
Hi Nghtcrwl,
add the "visible" property to the first property node an connect a true to it. The first worksheet is index 1.
Mike
Message Edited by MikeS81 on 07-22-2009 03:17 PM
Message 9 of 15
(4,812 Views)
Hi Mike
Thanks...
One more question. What if i want to save the opened template in another name and at another folder? I tried to change the invoke nodes at the end to method "save as" but didnt work.
Nghtcwrlr
Message 10 of 15
(4,802 Views)
