Wrong OS Error When Installing Internet Developers Toolkit 5.0 in Windows 2000 Advanced server
When I install the LabVIEW Internet Developers Toolkit 5.0 in Windows 2000 Advanced Server, the installer displays a Wrong OS error. I HAve ignored the error and contiued the installion still the Internet connectively pallete does not apper in my function Pallete .How do I resolve this error?
(2,672 Views)
You might try reinstalling the toolkit but the installer should have created the following directory:
C:\Program Files\National Instruments\LabVIEW 6.1\vi.lib\addons\internet
Within this folder, there should be a folder for:
ftp
http
smtp
telnet
url
utils
and a file dir.mnu
It could be that the toolkit was intalled to the wrong folder. In which case you can move the folders and reboot LabVIEW.
(2,672 Views)
Answer: Don't worry about it. I had the same problem with installing under W2K. However, the toolkit installs just fine and runs perfectly (or at least as well as it does on any platform). Just click through the error and go about your business 🙂
(2,672 Views)
