Wrong "Current VI's Path" in LV 2009
Klaus,
the primitive "Current VI's Path" always did, and presumably always will return the complete path to the vi. If the vi resides in an executable, the primitive always did (and always will be) return the path like <Exe-path>\<name of exe>.exe\<name of vi>.vi.
There has been no change in LV 2009 in this regard.
The thread Daniel linked to lists all changes in regard to executables build with LV 2009. Setting the checkmark in "Use LabVIEW 8.x File Layout" will force LV to build executables like LV 8.x and earlier did.
The change done in 2009 will therefore only take place if this setting is not selected and only for VIs in a subfolder in regard to the toplevel VI.
Is it possible that you were using a special subvi looking the same but truncating paths as needed?
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 11 of 31
(2,130 Views)
Ben wrote:
[...]I have a a re-use VI that I have been using since LV 6.0 to resolve the differences in paths between the development and exe environments. [...]
Ben
Let me guess:
There is something in it with "Call Chain" and other decent stuff, right? 🙂
Norbert
Norbert
Expert: Geometry
Message 12 of 31
(2,117 Views)
Norbert B wrote:
Ben
Let me guess:
Norbert
I would guess just an application.kind property node with an additional strip path in the "Run Time System" case  Smiley Happy
Message 13 of 31
(2,106 Views)
Norbert B wrote:
Ben
Let me guess:
Norbert
Actually mine is a more flexible in that it does not depend starting with VI path. It works by repeatedly striping the path until a folder is found.
Yair posted some code that illustrates the idea in this thread.
My re-use code is very similar to the While loop but with different checks and error checking thrown in for good measure.
Ben
Message 14 of 31
(2,104 Views)
Norbert, Daniel and all
Using the switch "Use LabVIEW 8.x File Layout" solves my problem.
Attached is the vi, that does not work without this switch.
This very old VI (worked from LV6.x til 8.2.1) also detects, if it is called out of an *.exe and activates the "Runtime" boolean.
Origin of the *.exe:
F:\Projekte\RFbeam_DT1\DT1_LabVIEW\Builds
Return without compatibility switch:
F:\Projekte\RFbeam_DT1\DT1_LabVIEW\Builds\DT1-Remote.exe\RFbeam_DT1\DT1_LabVIEW
It is obvious, that a "runtime detection" does not work with this interesting path output.
Return with compatibility switch:
Thanks for all your answers!
Klaus
Message 15 of 31
(2,081 Views)
Accepted by topic author Klaus_M
Klaus,
yes, "runtime detection" in thismanner is not recommended. LV 2009 keeps the folders of the modules in the executable, so this approach does not work anymore in LV 2009.
Either you move the VI in the rootfolder of your toplevel VI (so two folders up \RFbeam_DT1\DT1_LabVIEW )  or use the call chain approach as Ben uses.
hope this helps,
Norbert
PS: Keeping the setting for the file layout might be a temporary working solution, but i would not recommend you to stick on this.
Norbert
Expert: Geometry
Message 16 of 31
(2,085 Views)
I should point out that LV 2009 also has a new VI (I believe it's called "Application Directory" and is in the file constants palette) which returns the folder of the application, similar to what the image Ben posted shows. In the EXE it returns the EXE's folder and in the IDE it returns the project or top level VI folder. If you do want the folder, you should use that from now on.
___________________
Try to take over the world!
Message 17 of 31
(2,058 Views)
Norbert
I was too speedy. The call chain solution did not work in the real application without the compatibility switch, where the "call chain trick" is in sub VI.
It returns as a "Program Path" the same path as my original VI:
instead of
But why do it complicated, if it works as simple? 🙂
Attached is the VI code in for LabVIEW2009
I hope, this helps
Klaus
Message 18 of 31
(2,042 Views)
It would be a good practice to close the application reference 😉
Klaus
Message 19 of 31
(2,010 Views)
Klaus,
the call chain approach works fine if the ultimate caller is located directly in the <name of exe>.exe. The call chain is just a list of VIs whicht are executed in the hierarchical order until finally "Call Chain" is called. Please note that the VIs names are in the list in inverted order, so the last entry should be the ultimate caller (or origin if you prefer this).
But as tst already wrote (and like you tested): it is best to use the Application Directory.vi from the File Constant palette.
Norbert
Norbert
Expert: Geometry
Message 20 of 31
(1,999 Views)
