X Y simple function graph representation (harmonic movement)
Hey guis ! I'm new in labview and  I want to represent on a graph a simple sinusoidal function y(t)=A*sin(w*t+f) ( harmonic movement law) where A is the maximum amplitude and y is the amplitude in function of t(time). A, w and f are introduced from keyboard in a numeric field. f-is the initial phase , it means that in t=0 the amplitude is y=A*sin(f). What I don't know is how to put time in this function, please help me Smiley Happy Thanks a lot!
Message 1 of 9
(4,149 Views)
Accepted by cismarel
You can create an array of times using the "ramp pattern". Now simply apply your function and you'll get an array of Y's to be fed to a waveform graph. No loop needed. Adjust x0 and dx of the x-axis according to the ramp.
Use an event structure so the recalculation only occurs when one of the inputs changes.
See how far you get. 😄
Message 2 of 9
(4,135 Views)
i will try this, thanks a lot my friend Smiley Wink
Message 3 of 9
(4,130 Views)
Note that there are also functions that generate a sine pattern directly (sine pattern, sine wavesine_waveform, even the simulate signal express VI) . You simply need to transform your inputs suitably.
Here's how a literal implementation using the ramp would look like. Modify as needed.
Message 4 of 9
(4,114 Views)
can you attach  the project because i need it for school at physics. i don't know how to add a ramp pattern. Thanks you a lot , it really helped me to get more of labview .Smiley Happy
Message 5 of 9
(4,066 Views)
i managed to add ramp pattern but i don't know what's until the waveform graph :-??
Message 6 of 9
(4,062 Views)
Is this a question or a comment? Are you still having problems?
Message 7 of 9
(4,047 Views)
The two other nodes that are used are Sine and Bundle.
Tanya Visser
LabVIEW Group Manager
Message 8 of 9
(4,033 Views)
i managed to handle with the waveform buider, there was a problem connecting the start variable with the t0 of the graph, i did the conection with a time stamp converter , now i want to make this project an exe in worder to send it to my physics teacher. I'm very thankful guys . Have a productive day!
Message 9 of 9
(3,993 Views)
