X axis time is not working on waveform chart
Here is the updated code.
I'll get right into reading about these architectures. Sounds exciting after having to deal with so much code. Smiley Very Happy Thanks
Message 11 of 14
(1,201 Views)
Those charts are in a case structure so they will only update when that case is True.  I can't figure from the code how that elapsed time VI will disconnect your charts.
Message 12 of 14
(1,175 Views)
The user inputs a value that will determine how long the elapsed time vi will run until it says true. Bascially a way for the user to control how often the charts are updated. However, I am thinking of replacing this with the DAQmx timing VI since that seems to make things simplier. That means I'll also have to replace the DAQ Assistant with all the necessary DAQmx functions.
Message 13 of 14
(1,141 Views)
Accepted by msiwk
Alright, I fixed the problem. Not sure where the problem was, but I guess the t0 was getting lost somewhere (not sure where) so I decided to just rebuild it. So I used the build waveform VI and passed the orginal data to the Y (well actually an average of 5 data values to the Y), set the dt to 1, and used Get Date/Time in Seconds for the t0. The Get Date/Time seemed to fix it in case anyone is interested. I'll put this post as a solution, though it feels weird to use my own post as a solution haha.
Message 14 of 14
(1,126 Views)
