X-scale only arbitrary in Labview v2009
Hi Ben,
the example runs flawless after linking to the correct subvi and replacing the reference control with a constant...
Which path do you store your LV examples?
Edited:
After loading your snippet I can't close the vi anymore... Next bug?
Message Edited by GerdW on 08-21-2009 03:59 PM
Message 11 of 17
(2,040 Views)
Ben - Thanks for the interim fix.  Will work in a pinch.Robot Happy
Message 12 of 17
(2,023 Views)
I have files a Corrective Action request for this situation. Thanks for bringing it to light and I apologize for the inconvenience it causes.
Anna K.
Message 13 of 17
(1,998 Views)
Anna K.
And the CAR is..... ?
Ben
Message 14 of 17
(1,987 Views)
This was reported to R&D (#184049) for further investigation. A workaround was provided by Ben. Thanks for the feedback!
( Ben > Smiley Tongue )
Message 15 of 17
(1,980 Views)
Anyone knows if this has been corrected in the newer version?
I'm having the same problem but with Chart...
The workaround seems good but since I have many chart and I updating them pretty quickly, I fear that writting to properties nodes like that will be too much time consuming.
Thanks!
Message 16 of 17
(1,703 Views)
It was fixed in the first service pack of 2009, and I just installed 2010, so I have not been able to test that yet.
This was a quick fix for them and a priority... they took care of it!  Thanks
Message 17 of 17
(1,697 Views)
