XControl on an RT Controller?
I searched the forums and the NI website for an answer to this question, but haven't been able to find one.  Is it possible to use XControls on a Real-Time system?  I'm using LV 8.5.1 if that helps any.  Thanks.
(3,456 Views)
Hi nowelji,
You actually can find an answer by right click on your Rt target>>New, and as you can see, there's no Xcontrol, right?
This means XControl doesn't support on RT.
I believe the reason behind this is that an RT application doesn't really have a user interface on RT target itself.
Regards, Kate
(3,449 Views)
I think that the absence of an XControl on RT is that there are no user events on RT.
Ton
My LabVIEW Ideas
(3,397 Views)
Accepted by nowellj
No, X Controls are not supported on our RT Targets
Hunter
(3,367 Views)
