XML file data
Hello all,
 From here on..whoever visits this post..dont forget to go through my solution and if it feels good..dont forget to give kudos...Smiley Tongue
Thanks and regards,
srikrishnaNF
Srikrishna
Message 11 of 22
(2,196 Views)
I tried with your example to get the "TraceSessionDump/TraceList/Method_Enter/Parameter/Element" field from the attached xml file but couldn't succeed, although there was no error.
Could you help me on that?
One has to rename the attached file to XML
Thanks in advance
Y3G
Message 12 of 22
(2,158 Views)
Hi Y3G,
Take a look at some of these links, they should help you learn how to extract data from your XML file.
Parsing XML Files in LabVIEW
http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/parsing_xml_files_in_lv/
How to extract data from an arbitrary xml file and export in a nice csv file?
http://forums.ni.com/t5/LabVIEW/how-to-extract-data-from-an-arbitrary-xml-file-and-export-in-a/td-p/...
If these don't help you solve your issue please tell me more about whats going on. You said you did not get an error but are you able to extract any data from the file? What are you having problems with?
Tim O
Message 13 of 22
(2,134 Views)
Hello Ray,
I'm trying to design a similar VI, but  no luck. Is it possible that I could get a copy of your VI that's compatible with LabVIEW 8.6?
Jose
Message 14 of 22
(2,104 Views)
Hello Jose
To use the attached vi, download the xml file from the sunnywebbox (it will come down in a zipped format). Let the vi know where the file resides, and then run the via. The vi will open up the xml file and display all data values.
If youy have any questions regarding details let me know.
Ray
Message 15 of 22
(2,101 Views)
sorry....these are in 8.6 version
Message 16 of 22
(2,100 Views)
and more
Message 17 of 22
(2,099 Views)
Thanks for the files; however, I still can't seem to open them. LabVIEW tells me that they are in LV 10 format.
Jose
Message 18 of 22
(2,078 Views)
Message 19 of 22
(2,067 Views)
Hey Ray,
I tried to use the VI's you send me, but I don't have the "Get all Matched Nodes" VI. This labview library is not available for LV 8.6. I'm trying to find a way to do it on 8.6, but so far no luck. Do does function let you see the block diagram within it?
Jose
Message 20 of 22
(2,050 Views)
