XML file data
Hi Jose,
Did you had any luck? I have the same Problem....
Could you provide me with a VI that works for LV8.x ?
Many thanks in advance
Y3G
Message 21 of 22
(713 Views)
Hey Y3G,
      Unfortunately, the Get All Matched Nodes.vi uses functionalities that are not available in LabVIEW 8.6. For conversion from xml to txt in 8.6, I recommend you look at the VI here:
http://forums.ni.com/t5/LabVIEW/how-to-extract-data-from-an-arbitrary-xml-file-and-export-in-a/m-p/9...
It may require some minor changes for your application, but it should get you started. Hope this helps!
--Ryan S.
Message 22 of 22
(682 Views)
