XNET Read Waveform Issue
Hi, I have a problem reading CAN signals after power down the bus participant. I configured the XNET as "Signal In Waveform" with a resampling rate of 50kHz. The participant is switched off and I receive the standard signal value (defined in the database). After switching the power supply on I receive the correct value, BUT after switching the power supply off again I still receive the last value - not the default value. Does somebody has an idea?
Message 1 of 1
(2,206 Views)
