XNode
Message 1 of 18
(6,032 Views)
It might be protected, goto XNode properties>Protection and check the protection level. If it is password protected then you amy need to enter password to keep it unlocked.
Message 2 of 18
(6,023 Views)
Message 3 of 18
(6,017 Views)
My bad. You are trying to open a library which is password protected and can be open by NI only as it shows in the message. Why do you want to open the library anyway? BTW its not your XNode 😛
Message 4 of 18
(5,962 Views)
Thank you! But this XNode below has no password,but it's locked. Can you open it in your computer?
Message 5 of 18
(5,958 Views)
Hi enen,
as the error message says: You don't have the proper license to edit that XNode.
Me neither: I can load/open the files, but can't edit the XNode…
Message 6 of 18
(5,932 Views)
XNodes are super secret and are just in general are for NI purposes only.  You have to have a special NI-only license in order to edit them inside of LabVIEW.  But if you head over to LAVA, there is a good discussion on XNodes.
Message 7 of 18
(5,922 Views)
But why others on the Internet claim that thay can create XNodes? It isn't top secret. Is that I didn't active something?
Message 8 of 18
(5,912 Views)
You can, you just can't edit  it in LabVIEW.  Head over to LAVA and do a search and you will find instructions.
Message 9 of 18
(5,859 Views)
Should I active LabVIEW on-line?
Message 10 of 18
(5,793 Views)
