silly question - large numbers
im having an issue, simple really. im sure im being a bit stupid.
i am incrementing a large number to an indicator i/u64 but when it it gets to about 2 billion it goes negative.
im sure it should be a bit bigger than that.
if not, how can i get the indicator to increment into the tens of billions
regards
(3,995 Views)
Accepted by topic author slugger
Hi slugger,
such questions are answered best with an example VI of yours…
I64/U64 should allow a much larger range than ~2e+9 - infact in the order of 1e+19!
So it seems you used an I64 indicator but you still calculate using I32 values…
(3,989 Views)
im getting number of bytes written from tcpip write then via a shift register am adding on each loop.
im guessing the shift register is 132? or the addition?
hmmm just checked it
my addition was I32
many thanks
wouldnt have guessed that for a bit !!!!
many thanks
(3,970 Views)
If solved your issue, it would be nice to give him credit in the form of a marked solution.  🙂
Bill
CLD
(Mid-Level minion.)
(3,948 Views)
done
ta
(3,933 Views)
