XY Graph Axis Custom Scale
I have a graph in excel that I am trying to duplicate in labview.  I'm having trouble setting the scaling for both axis so they look like the excel graph.  Any suggestions?  I attached the vi I'm using that just plots one line currently.
Thanks.
LabVIEW 2016 - Windows 7
CLAD
Message 1 of 9
(6,213 Views)
here is how to do multiple plots on a XY graph
- there is always an easy way, but it is always the hardest to find
Message 2 of 9
(6,204 Views)
Could you save your example in 8.2?  To be clear my issue wasn't multiple plots but rather the scale labeling for the x and y-axis.  I can't seem to format them like in the picture.
CLAD
Message 3 of 9
(6,200 Views)
Right click the graph and select properties\scales to adjust the look of the numbering of the scales
Message 4 of 9
(6,192 Views)
Tried that with no luck, just wouldn't give me the results pictured.
CLAD
Message 5 of 9
(6,189 Views)
Are you trying to duplicate the scale values or the scale labeling?
Message 6 of 9
(6,173 Views)
Scale vaules.....so for the x axis 63, 125, etc.....but I can't figure out how to do it.
CLAD
Message 7 of 9
(6,160 Views)
If you create a property node of the x scale marker values, you can control the displayed x scale values except the min and max values are always displayed. Also make sure the x scale style is select to display the intermediate values.
Message 8 of 9
(6,153 Views)
That did the trick....thanks for sticking with me and helping me out.....
Bobby
CLAD
Message 9 of 9
(6,125 Views)
