XY Graph Max Y with corresponding X
I am currently working on obtaining max values from an XY graph. I can obtain the Max Y values from my input array, but I am unsure how to obtain the X value corresponding to the Max Y value. I have read somewhere about using max index(es) on the Array Max Min function but that leaves me with the location of the x value. How do you go from there to obtaining the actual x value? Thank you.
(3,053 Views)
Accepted by Zzimmha42
IndexArray your X array with the index you found...
(3,047 Views)
