XY Graph shows phantom dots when zoomed
I did just recently notice that I'm using the line plus single pixel marker.  Can't remember if that was intentional or a typo.  I have a feeling that choice might be related.  Just counted them up - 21 XY graphs in total - ugh.
Message 11 of 23
(1,600 Views)
That's it.  Now I see the dots whenever I choose the single pixel as the point style.  Regardless of the line style, the single pixel points show up as those 'phantom dots'.  Even in a brand new graph.
Forget that piece of advice!
Message 12 of 23
(1,592 Views)
The dots in the graph exist. They stay there if you export to image to emf, which is a vector image format. They even appear connected in my emf.
Message 13 of 23
(1,588 Views)
I'm seeing it too. I've played around with it for a little way but can't explain it yet. I'm tracking down some angles with R&D but I think this is going to be chalked up as a bug. Just the fact that it goes away with other plot point styles seems bug-ish. I'll keep you posted with what I find out. I haven't been able to find an existing bug report that matches this behavior or a workaround yet.
Message 14 of 23
(1,587 Views)
But they are not exported to Excel. They are somehow connected to the graph but not to the plots.
Message 15 of 23
(1,581 Views)
I also tried a smaller subset of the bundled arrays (during a timeframe that showed the ghost data points) but it doesn't show up in smaller datasets.
Message 16 of 23
(1,574 Views)
I'm able to re-create this problem now on any style xy graph - using a line WITH markers and the marker set to the single pixel point (a 10 when changing progamatically).
Thanks to Darin K for this observation.  I think this was a typo on my part or a misunderstanding of the codes for the programatic plot type setting.  I don't really know what the application for this type marker would be.  I set to line without marker (code 0) and problems dissappear.  Problem solved for me - but seems like there's still a bug to work out for NI(?)
Thanks all for the help.
Tim
Message 17 of 23
(1,550 Views)
Hey Shan,
I am the applications engineer you were coresponding with via email. I filed a Corrective Action Report, the number is #390619. The report is currently being processed and prioritized by the R+D team. You can use this number to see if the request was addressed in future releases of LabVIEW or can call to check the status.
Thank you,
Kurt P
Automated Test Software R&D
Message 18 of 23
(1,529 Views)
Hi Kurt
Have discovered same problem: When using pixel-size points I get phantom-points in my graph when I zoom in. These points are actually real points nearby the zoomed-in area, that are "draged" into the zoomed area when they should have been outside. When changing point-type they disappear, and all is normal. I was wondering what's the status of the bug-fix, and if we have to wait for next release of LV 2013 in Aug, or if we can download a fix soon?
If not, will installing LV2011 and build my exe in 2011 fix the problem or does it have the same bug?
Regards
Bård
Message 19 of 23
(1,486 Views)
I'm using LV2012 + win 7 and the problem still seems to persist. Within a x,y plot, independent of the kind, if classic or silver etc, i one of the point styles that include a single pixel as point representation is selected, then ghost points appear if one zoomes into the vicinity of 1 or 2 points. the more zoom, the more ghost points seem to apperar.
The point representations  4, 8 and 10 (property node plot.pointstyle) are the ones with the pixel point.
The data into the graph and from the graph seems not to be influenced.
Message 20 of 23
(1,409 Views)
