XY Graph shows phantom dots when zoomed
Hello GybrushThreepwood,
Is the phantom data that you see selectable? If not, then this is likely only a video artifact and will not affect the plot at all. If you place a new graph down does the issue persist?
Also, you might also try posting your question as a new thread. This will result in more community visibility which will lead to more conversation about this problem.
Gerald M.
NI
Message 21 of 23
(538 Views)
Dear Gerald,
Thanks 4 the reply! I think im fine with the behavior, I mean I can live with that.
Solution 1:  I just set all the plots to a "non-single pixel" representation via property node.
Indeed it is a plot that i probably have loaded from an earlier version of labview. I just checked a new x,y plot with calculated data if something similar occurs. There seem to be no problems at all: Not a Solution 2: I tried to just replace the graphs with new ones! But the strange behavior is still there!
For those who might find some similar problem I've attached a png. You see the data (white points), and a fit (red squares). When you zoom in then if you are in a 1-2 measurement point range then it starts to show extra pixel points. If you zoom further more points occur on different positions. I wanted to check the fit by looking at the graph.. therefore i was suprised! But if one knows the behavior its no problem at all. Especially with the easy solution. BTW: The error pixel color changes as the plot point color is changed. Export data from the graph do not include error data!
Best Regards, Gybrush
Message 22 of 23
(518 Views)
@GybrushThreepwood wrote:: Not a Solution 2: I tried to just replace the graphs with new ones! But the strange behavior is still there!
Be sure you aren't just do a "replace" of one graph with the other.  Drop down a new graph, delete the old, and fix up the wiring in your block diagram  The problem with a replace is that the "new" control/indicator often inherits properties from the old one and if there was a problem with the old one, maybe that issue gets transferred to the new one.
Message 23 of 23
(513 Views)
