XY Graph with No Lines, Just Points?
Hi All,
I want to build a Pressure vs. Temperature graph.  This should be a standard XY graph, but I just want to see the point scatter with no lines connecting the points.  Is there a way to eliminate the lines between the points (or make them invisible)?
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(4,814 Views)
Accepted by diarmaede
You can do it in graph properties. Right click on graph and select Properties. Go to the Plots tab.  Select a point icon (anything other than <none>) in the third column of icons. Next select the top-most selection in the fourth column. It's the symbol with the plot points but no lines. This will give you waht you want.
(4,809 Views)
How the heck did I miss that?!  Thanks!
Forbes Black
(4,805 Views)
