XY graph in MS Office Report Express VI
I tried using MS Office Report Express VI with template as Custom Report (with a  *.xltx  template). But when i tried to insert a XY Graph (a 2D array with Row(0) as X axis values and Row(1) as Y axis Values) with 'Value Source' : Input ; and 'Input Appearance in Report ' :Graph;  onto the excel report, it shows a entirely messy output as shown below.
Message 1 of 16
(5,090 Views)
I've not used that express VI, but it looks like you're graphing Y vs. Y.
Message 2 of 16
(5,085 Views)
Hi Gregoryj,
Please see the new edit i made.The image i loaded initially was wrong.
Message 3 of 16
(5,075 Views)
Can you upload the VI or a snippet of the VI so I can take a look? I'm using LabVIEW 2014.
Message 4 of 16
(5,065 Views)
Please attach your VI so we can see what you are doing.  For doing anything that is the least bit "unusual" (like inserting a Graph into an Excel Workbook), you should not use an Express VI.  It is really simple to create a Workbook with an embedded graph -- I posted an example here in the Forums a few years ago (I'll try to find it, but I think if you search for "Revised Example", it will pop up ...).
P.S. -- note that what I was posting was a revision to an Example that came with LabVIEW.  I haven't looked at the currently-shipping Examples for RGT, but those would also be a good place to look for suggestions ...
Message 5 of 16
(5,051 Views)
Looks like you need to transpose the 2D array.
Message 6 of 16
(5,014 Views)
Hi All,
Thanks for the inputs.
Please find attached the code and also the excel generated.
I actually wanted to get an excel sheet with both arrays and also the labVIEW graph of the same.
The only problem in the excel sheet is the messed up graph. I would want to get the exact same graph that i get in the front panel, on my excel too.
I tried Transposing, concatenating the array.. and all. Nothing worked.
Please help.
Message 7 of 16
(5,001 Views)
Please find attached a version with the template file also attached. I forgot to attach the same before.
Please change the properties of the Express VI to map the template file and location to save accordingly.
Message 8 of 16
(4,984 Views)
Transposing the array fixes your problem.
Message 9 of 16
(4,973 Views)
Sorry, forgot to save my changes before I uploaded it.
Message 10 of 16
(4,965 Views)
