XY graph overlay on video from videocapx
I have been using labview for a while, but am facing a different problem this time.
1. I need to overlay an XY graph (the data for which I am getting from another DSP board) on to a video.
2. I have succesfully been able to make the XY graph transparent. and also put the XY graph on the video window from the videocapx.
    I am using the 30 day trial version of videocapx and an example. is being attached.
    I am using a logitech webcam. The output of which I can succesfully see in labview.
But my problem is the points from the XY graph are hidden behind the video window and I cannot get them onto the video.
And hence cannot overlay them.
Any help will be appreciated.
Thanks in advance
Gaurang
(3,125 Views)
Please also note that I donot have to store th video and I will not be changing the video information.
It is just for visual information that I want the information from the XY graph on top and visible on the video and hence I made the XY graph transparent.
Thanks again
(3,120 Views)
Hello Gaurang,
I ran your VI in LabVIEW 8.6.1.  The white points appear over the control.  However, this behavior may change when the control is active. (I don't have your hard-/software.)
Though it already appears to be there, have you tried specifically bringing the graph to the front on your Front Panel?
(3,098 Views)
