XY graph plot fill
I am plotting waveforms on a XY graph vertically. I have tried to use the fill to option but it does not seem to work correctly, is there a way to set the axis in which the graph defines its fill to?
- there is always an easy way, but it is always the hardest to find
(5,985 Views)
You can specify the "fill to" to be zero, +infinity, -infinity, or another plot. There's no option for axis. Can you provide a screenshot of what you're trying to accomplish? Perhaps there's another way to do it.
(5,960 Views)
If you look at the picture attached, I am trying to acheive the waveform on the right hand graph, but in a vertical waveform. When I try this in the XY graph with a vertical waveform I get the left hand result. I am trying to fill to zero. I am using two overlapping waveforms to acomplish the only positive fill to zero.
(5,952 Views)
Isn't the right-hand graph a "vertical" waveform? I guess I'm not understanding what you mean by "vertical" waveform. Also, the left-hand graph seems to be a waveform graph, not an XY graph.
(5,943 Views)
Sorry, one of those days, I got my left and right mixed up.
So I am trying to acheive the left hand graph but in a vertical sense, but I am only getting the right hand graph when I try to fill to zero with a vertical waveform on a XY graph.
(5,941 Views)
There may be other ways to do this, but if I understood it correctly, I did it using 2 plots. See attached example (LabVIEW 8.2).
(5,930 Views)
thanks that should work
(5,926 Views)
