XY graph plotting issue with repeting data inside loop
            I have this issue I am having with my plots. Maybe there is a better way to do this.
            I have a set of data that I am using inside a loop. I want the loop to keep reusing the same data over and over. The reason I am doing that is because I want to continuously stream data that loop exactly like the one in my data file and plot it and do other different things with it. My problem is the XY graph is not plotting it properly. I wonder if anyone can help me get the plot working and alo get the data moving accross the waveform XY graph.
Files are attached. Test.vi is the main vi
Admin Note - Attachments removed per user's request
Message 1 of 18
(5,511 Views)
THe glaring problem that i see is you are trying to read from an XLSX file rather than a CSV.  Spreadsheet string to Array reads from a text file.  If you want to read from Excel native format, you need to use the Report Generation toolkit to read the values.
aputman
Message 2 of 18
(5,504 Views)
Thanks for replying, but I guess I didnt pay attention to that. But nevertheless it reads it and I get the right data out. Here's a copy in .txt format
Message 3 of 18
(5,481 Views)
An XY graph doesn't have history.  If you want the data to "move across the graph" as you add more data, you'll have to use a waveform chart.  Am I understanding your question correctly?
aputman
Message 4 of 18
(5,476 Views)
Well yea, but when I build a waveform and use a waveform chart I have gaps in my data. Since Im streaming the same set of data, each time the loop iterate I get a new same of the same data but in between there's an empty space. Also if i change the channel, then the previous channel has to be gone of the display before seeing a full view of the then selected channel.
Message 5 of 18
(5,464 Views)
Replace the XY Graph with a waveform chart and wire as shown.  To clear out the previous history, you'll need to detect a change in value of the listbox.  When a change occurs, wire in an empty array to the History property node for the chart.
aputman
Message 6 of 18
(5,453 Views)
Thanks for replying but I am alos trying to use the right time stamp for the data im displaying on the plot. Which I noticed you didnt implement in your snipet
Message 7 of 18
(5,423 Views)
Also that technique did not work.
Message 8 of 18
(5,419 Views)
You are going to have to explain your requirements better because it works for me (at least my understanding of your requirements).
aputman
Message 9 of 18
(5,413 Views)
If you want a timestamp on the X-axis, use the build waveform node.  However this won't give you what you are looking for with this sample data, if you want the plot to keep "moving across the graph".   This is because the waveform is going to have the same x values every time.  It's essentially plotting the data on top of the previous plot.
aputman
Message 10 of 18
(5,399 Views)
