Xilinx Compilation Error: HDLCompiler:432 Formal <eiosignal> has no actual or default value
Hello everyone,
I've gone through the code and found a section that had a disable structure around a section of the code that would enable or disable the output setting of the DIO ports. I deleted these sections (they were there from an early version), and the FPGA program compiled like a charm. Thank you all for your help and insight.
DiracDeltaForce
Message 11 of 11
(591 Views)
