Xml Attributes
I would like to know how to extract xml node attributes without knowing the names of those attributes. Is it possible using the XML parser of labvew 2010?
For example say I am reading in the below xml structure:
<node_1>
 <node_2 name = second_node> text </node_2>
 <node_3 type = a>
<node_4> text </node_4>
 </node_3>
</node_1>
The programmer has no knowledge of the xml structure or content when writing. How do I extract the attributes of each node?
i.e. giving the results: { {name, second_node}, {type, a"} } .
Thank you,
labjunky
(4,388 Views)
Accepted by topic author labJunky
Assuming you are actually going to provide well-formed XML with quotes around the attribute values, XPath is your friend.
(4,378 Views)
Darin, thanks a lot!
XPath is great.
Do you know a good reference for more such tips and tricks?
thanks again,
labJunky
(4,361 Views)
