Yokogawa driver directory structure
We have a Yokogawa Frame Controller AQ2211 and I downloaded YKAQ2201.zip from their website.
We also have the AQ2200-421 module which is in the frame, and I downloaded YKAQ2200-421.zip from their website.
The two zip files unzip into the following directory structure:
    --- YKAQ2200-421   [this is a directory]
        --- YKAQ2200-421   [this is a directory with 5 files]
            actstat.mnu
            applic.mnu
            config.mnu
            data.mnu
            dir.mnu
            util.mnu
        --- YKAQ2201    [this is a directory with 1 file]
            YKA2200-421.llb
    --- YKAQ2201       [this is a directory]
        --- YKAQ2201        [this is a directory with 7 files]
            _YKAQ2201.llb
            actstat.mnu
            applic.mnu
            config.mnu
            data.mnu
            util.mnu
            YKAQ2201.llb
I placed the directories as-is into LabVIEW's instr.lib, but I am not able to access the VIs inside the LLBs.  These drivers are for LabVIEW 2010, and I am using LabVIEW 2012.
I had read that there was change from 2010 to 2012 with regards to instrument drivers.
I am not sure how to re-arrange the directories.
Yokogawa claims that their drivers are right. I have tried re-arranging the directories, but nothing I tried has worked.
(3,795 Views)
Accepted by topic author njacacia
I figured out what was the problem.
The Yokogawa drivers did not like being inside a directory Yokogawa that was created under instr.lib
Final directory structure:
C:\Program Files (x86)\National Instruments\LabVIEW 2012\instr.lib\
        actstat.mnu
        applic.mnu
        config.mnu
        data.mnu
        dir.mnu
        util.mnu
        _YKAQ2201.llb
        actstat.mnu
        applic.mnu
        config.mnu
        data.mnu
        util.mnu
        YKAQ2201.llb
        YKA2200-421.llb
(3,782 Views)
