FORCE STOP WHILE LOOP WITH TIME DELAY
Hi Guys,
 I'm doing a project that will datalog the voltage reading from Arduino A0 pin. The arduino will read the voltage reading every "N" times (depends on time delay) and save the overall reading into excel. The problem is, I can't stop the VI anytime I want.
seems like it will wait first before the delay is finished. see the attached picture
Message 1 of 13
(7,211 Views)
Put the time delay in the false case of an case structure. Wire the stop button to the terminal of the case structure. I have build an example
Message 2 of 13
(7,202 Views)
Hi Gert-Jan,
you still can't stop your loop when the delay function is called!
@dragon:
Better try something like this:
(ElapsedTime is set to auto-reset.)
Message 3 of 13
(7,179 Views)
So to abort the delay you can abort the SubVI.
Message 4 of 13
(7,170 Views)
Hi Gert-Jan,
usually you don't want to abort a VI somewhen in the middle of doing something important…
(What does Wiebe say about your recommendations? :D)
Message 5 of 13
(7,162 Views)
I think it is best practise to use the abort VI function only if you have absolutely no ther option.
ʍolɟɐʇɐp ʞuıɥʇ
Message 6 of 13
(7,159 Views)
Hey GerdW
Probably he doesn't agree. I agree these suggestion that I made were not great. I should pause and look at the problem more carefully before I suggest a solution. I assumed that the question was about stopping a Time Delay without thinking about the actual question.
The first solution has indeed the issue that it doesn't stop an already started time delay. The second solution stops the time delay but forces the application off while not closing references properly.
Message 7 of 13
(7,146 Views)
@GerdW wrote:
Hi Gert-Jan,
Well, "Abort" is about the only way to stop a time delay. So I think it should be the accepted answer!
Let's stay on topic for once! How to avoid having to stop the time delay is another (the correct) question.
Message 8 of 13
(7,134 Views)
Place the code in an event structure in the timeout case (timeout = rate), then you can have a Stop Value change event that'll stop at any time.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 13
(7,113 Views)
I think it's suppose to run on Arduino (not sure), so no event structures.
Message 10 of 13
(7,106 Views)
