FORCE STOP WHILE LOOP WITH TIME DELAY
Accepted by topic author dragonknight255
I would suggest you to try out the following approach. It is like making the time delay into small chunks of time delay within which you want your VI to respond for Stop button press.
Message 11 of 13
(1,727 Views)
Or like this (less efficient, maybe(?) a easier to grasp):
Note that this will still work when the U32 reaches it's maximum value.
Message 12 of 13
(1,718 Views)
The OP is using the LIFA toolkit running on the host computer to talk with the "sketch" (code) through serial. If I remember correctly it is set up at 9600 baud rate. Without knowing what his timing requirements are it is kind of hard to answer due to the overhead of serial comms. If it is not too demanding he could split the timing up into smaller chunks to make the user vi more responsive.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 13 of 13
(1,704 Views)
