Yokogawa wt3000 over LAN, tmctl.dll
thanks 🙂
I could add it.
Now, I need to know where to put the username in labview
Message 11 of 51
(2,921 Views)
Well that is basic LabVIEW knowledge.
Download the drivers from NI or Yokogawa and take a look at the example and getting started that come with the driver package.
Kees
Message 12 of 51
(2,910 Views)
I tried to run it but it always gives error in all "VISA Read"
Message 13 of 51
(2,896 Views)
What VI did you run and what is the error number? Did you tried to find the description of the error number ?
Try to run the initialize VI
Message 14 of 51
(2,880 Views)
I already tried many VI but the error is ever the same.
Error -1073807339 occurred at VISA Read in YKWT3000 Initialize.vi
Possible reason(s):
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
Is not necessary make a login?
Message 15 of 51
(2,878 Views)
First you must be sure that you have an connection with your instrument.
Try to ping the WT3000.
If that is OK. Make sure you did not add a different login and/or password with the network setting of the WT3000.
Did you add a alias in MAX ? and used this alias within your VI ?
Message 16 of 51
(2,874 Views)
I have tested the connection in MAX and it worked.
I have tried run initialize VI without id query check and it have ran without errors.
I see connect list in WT3000 and appear my login and logout.
My login are anonymous and I do not have a password.
Message 17 of 51
(2,867 Views)
I made a VI (in annex) and I try to use this. If I put 13 or less in byte count it works, otherwise it gives the previous error.
If I put the byte count equal to 13, in read buffer appears: "€ username:"
Message 18 of 51
(2,854 Views)
You can run the initialize VI without errors . So what is the problem This VI opens the interface and does a login on the WT3000. So you have a connection (when the VI runs)
Now try the examples that come with the driver.
The VI you made it too basic to setup communication with the WT3000.
Message 19 of 51
(2,851 Views)
I have the same error. I have ran initialize VI without errors but I put dont check id query and it dont run a case structure where is read block.
When I open the example1 some warnings appear.
C:\Users\Desktop\WT3000 drivers NI\ykwt3000\ykwt3000.llb\YKWT3000 Application Example1.vi (YKWT3000 Application Example1.vi)
- The VI expected to be at "<instrlib>:\ykwt3000\ykwt3000.llb\YKWT3000 Waveform Data Convert.vi" was loaded from "C:\Users\Desktop\WT3000 drivers NI\ykwt3000\ykwt3000.llb\YKWT3000 Waveform Data Convert.vi".
- The VI expected to be at "<instrlib>:\YKWT3000\Ykwt3000.llb\YKWT3000 Wait Update.vi" was loaded from "C:\Users\Desktop\WT3000 drivers NI\ykwt3000\ykwt3000.llb\YKWT3000 Wait Update.vi".
- The VI expected to be at "<instrlib>:\YKWT3000\Ykwt3000.llb\YKWT3000 Read Sample Rate.vi" was loaded from "C:\Users\Desktop\WT3000 drivers NI\ykwt3000\ykwt3000.llb\YKWT3000 Read Sample Rate.vi".
- The VI expected to be at "<instrlib>:\YKWT3000\Ykwt3000.llb\YKWT3000 Read Waveform.vi" was loaded from "C:\Users\Desktop\WT3000 drivers NI\ykwt3000\ykwt3000.llb\YKWT3000 Read Waveform.vi".
- The VI expected to be at "<instrlib>:\YKWT3000\Ykwt3000.llb\YKWT3000 Config Waveform.vi" was loaded from "C:\Users\Desktop\WT3000 drivers NI\ykwt3000\ykwt3000.llb\YKWT3000 Config Waveform.vi".
Message 20 of 51
(2,849 Views)
