Yokogawa wt3000 over LAN, tmctl.dll
In MAX I opened "Open VISA Test Panel", "input/output" and "write"(no error) and "read" (error).
The error is:
Read Operation
Error
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
PS: I already made the download of drivers by labview and delete the previous warnings...
Message 21 of 51
(3,079 Views)
Don't worry about the warnings. It just tells you that the VI are loaded from a different location than expected.
What happens if you run the example ??
Message 22 of 51
(3,072 Views)
It is ever the same error.
Error -1073807339 occurred at VISA Read in YKWT3000 Wait Update.vi->YKWT3000 Application Example1.vi->Untitled 1
Possible reason(s):
Message 23 of 51
(3,069 Views)
I am a bit confused now.
You said earlier that the initiliaze VI works OK ?
Message 24 of 51
(3,063 Views)
Yes but only if I put "check id query"="false", because thereby it passed not by the "Read" block.
Message 25 of 51
(3,061 Views)
My error, you mentioned the ID query.
But the Login also uses the Read. Can you probe the output of the ID query. Curious what your WT sends as an ID.
Next answer will be tomorrow when I am back at work.
Message 26 of 51
(3,059 Views)
I don't understand what you want said with "Can you probe the output of the ID query. Curious what your WT sends as an ID"
How can I see this?
Message 27 of 51
(3,058 Views)
I get a feeling that you knowledge of LV is not that good Smiley Wink
In LV you probe a wire to see the data when the VI runs. In the VI Initialize you can probe the string output of the Query VI. You can also open the Query VI and run the initialize VI and look at the front panel of the Query VI to see the output of the WT
Message 28 of 51
(3,052 Views)
Yes, but the inicialize VI do not have any Query VI :s
Makes long time since I worked with labview. Now I'm still remembering.
But I never had this problem. But also I never worked with this type of equipment.
Message 29 of 51
(3,035 Views)
It does have a query VI. See picture
Message 30 of 51
(3,027 Views)
