‎01-31-2009 12:57 AM
hi...
can we convert any file format(pdf,.doc etc) into a text file using labview ? i will be thankful if you provide me with the answer
Solved! Go to Solution.
‎01-31-2009 02:33 AM
Hi vamsi v,
if you know the file format, then you can write a converter with LabVIEW. For the doc format you can use ActiveX to read the content. There should also be an ActiveX support for pdf.
Hope it helps.
Mike
‎01-31-2009 08:38 AM
‎03-11-2010 02:55 AM
hi Mike can i have an example for this post:
Hi vamsi v,
Hope it helps.
Mike
Thank you
‎03-11-2010 04:33 AM
In which part you are asking support? In converter side? In activex for doc? In activex for pdf? Post in bit detail.
Mathan
‎03-11-2010 06:36 PM
In activex for pdf can i have simple example how to use active x for the pdf.. please
Thank you
Jeya
‎03-11-2010 09:07 PM
jeyanthi wrote:In activex for pdf can i have simple example how to use active x for the pdf.. please
Thank you
Jeya
‎03-11-2010 11:15 PM
Hi thanks for the help
but when i open the vi in labview 8.0 ..it shows some error..it can't detect the invoke node..pls help thank you
‎03-12-2010 08:51 AM
‎03-30-2010 03:45 AM
hi Jaya,
Here is the VI which is working in LV 8.6. Don't forget to press kudo,
Regards
rams
