ZICK ZACK problem
HI Everybody,
I am working on a project that involves two motors:
One motor moves along the X-axis.
The other motor moves along the Y-axis.
The intended movement pattern is as follows:
The X-axis motor moves from a starting point to an endpoint in steps at specific intervals.
Once it reaches the endpoint, it returns to the starting position with same intervals.
Then, the Y-axis motor moves one step forward.
The X-axis movement repeats after each Y-axis step.
Issue:
Instead of following the expected sequence, my system is executing the movement incorrectly:
The X-axis motor moves from the start to the endpoint in interval.
The Y-axis motor moves forward.
then X-axis move back with interval
Message 1 of 9
(2,785 Views)
You mean zig-zag?  If I understand your intention, you want the traversal on the left but your code is doing the traversal on the right.  If so, you need to adjust when to do the zag motion (Y-axis).  Unfortunately, I'm not going to try to decipher that spaghetti mess of an image. You need to look up how to use a state machine.  Labview ships with some examples or you can download templates from VIPM (JKI state machine, etc).
aputman
Message 2 of 9
(2,771 Views)
We cannot debug truncated images, but all you probably need to do is make minor adjustments.
Message 3 of 9
(2,760 Views)
Accepted by malik240
See if this can give you some ideas...
Message 4 of 9
(2,738 Views)
yes this is what i wanted but my problem ending in every direction there is a movement in y-axis due to type change.
Message 5 of 9
(2,686 Views)
I have absolutely no idea what you mean by that. What is a "type change" here?
Message 6 of 9
(2,683 Views)
OP, you should lose half the wiring and conditional code.
In fact I would copy altenbach's design, either for your solution, or to generate all the coordinates in an array first to then simply walk through them in order.
Keep it simple.  Generating an array first would help to see what is going on.
Message 7 of 9
(2,671 Views)
Again, I hope you understand that it is really impossible to "follow the wire" and figure out any logic from a picture showing wires flowing in all direction and deep stacks of case structures where only 10% of the possible cases are even visible.
Just look at what you gave us: It is impossible to tell what you are doing wrong!
Message 8 of 9
(2,636 Views)
Maybe this example will help...
https://forums.ni.com/t5/Example-Code/Generate-2D-Raster-Pattern-in-LabVIEW/ta-p/3503399
Message 9 of 9
(2,617 Views)
