Zebra TLP 2844 USB
copy tmp.EJF \\T-STOMFG-11\LpLarge
using the last command int cmd works fine, but using the system exe.vi doesn't work
Were \\T-STOMFG-11\LpLarge is the printer address
Message Edited by lmontoya on 09-08-2009 01:48 PM
Message 11 of 13
(3,779 Views)
What Windows version do you use? Did you at the cmd.exe to the front of the string that you sent to the System Exec? copy is an internal shell command so you need to start the command shell executable in order to execute the copy command. At least for Windows 2000/XP the command shell is cmd.exe. Not sure about Vista and/or Windows 7.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 12 of 13
(3,770 Views)
Accepted by lmontoya
I have XP, but thank you anybody, I allready found the solution and it's next:
cmd.exe /c copy Temp.EJF \\T-STOMFG-11\LpSmall
I just add "/c" afther cmd.exe command
the printer must be shared
Message 13 of 13
(3,761 Views)
