Zero Span Measurement using NI-Scope
Is there any way to use a NI PXI 5122 for a zero span measurement? I need to look at a 40 KHz incoming signal in terms of power (dBm) vs time (sec) instead power vs frequency.
Thank you in advance.
(2,672 Views)
Combine the power and time together manualy and pass it into the graph or chart of your choosing...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,648 Views)
