Zoom in on Block Diagram
How do I zoom in on a small area of the block diagram?
Message 1 of 84
(26,008 Views)
Unfortunately, the answer is, a magnifying glass.
NI has yet to implement a zoom function.
Sorry.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 2 of 84
(25,986 Views)
Are you referring to a sub-vi? (A square with graphics or text within it with wires running to it). Double click on it to open it up.
Message 3 of 84
(25,980 Views)
OpenG used to have a "Bird's Eye View Utility" to do this. Have no idea if it works with the latest version of LabVIEW or whether there's a newer version.
Message 4 of 84
(25,955 Views)
If I remeber correctly, Birds Eye View was replaced by the naviagtion window which lets you "Zoom out".
Decrease your screen resolution is an option.
Ben
Message 5 of 84
(25,949 Views)
As mentioned, LV does not yet have the option of zooming in, only zooming out (I don't remember for sure, but I don't think BEW could zoom in either, although that can be changed), but as Ed mentioned, you can use a magnifying glass.
Ed may have used this as a joke, but at least in Windows this is relatively simple - you need to open the magnifier (Start>>Programs>>Accessories>>Accessibility) and change its size and zoom level to fit what you want. Note that it can take up a significant portion of you screen.
___________________
Try to take over the world!
Message 6 of 84
(25,930 Views)
But uing a magnifier in the window doesn't help you to selct objects and manipulate wires.
Message 7 of 84
(21,615 Views)
2 years later I'll just add that this is a deal breaker for me.  The block diagram symbols are too small for my old eyes.  Changing the screen resolution isn't an option.  I'm only using evaluation version right now to analyze Labview code we inherited from a closed down branch of the company.  I'm leaning to rescripting the program in C# and dumping Labview, less headaches from eye strain.
Message 8 of 84
(16,660 Views)
@canyonbreeze wrote:
2 years later I'll just add that this is a deal breaker for me.  The block diagram symbols are too small for my old eyes.  Changing the screen resolution isn't an option.  I'm only using evaluation version right now to analyze Labview code we inherited from a closed down branch of the company.  I'm leaning to rescripting the program in C# and dumping Labview, less headaches from eye strain.If
If it's just a size-of-icons issue and not a bad-code issue, there must be a windows zoom utility out there you could use. I'm not sure if there is one, but I'll make the assumption someone has done it.
Message 9 of 84
(16,656 Views)
Message 10 of 84
(16,656 Views)
