a challenge to take up
I'm currently preparing my Phd in psychology and use a sensor system
describe here (http://www.ascension-tech.com/products/flockofbirds/)
which track the motion of a linb in space.
I used a software made with labview 5.0 that made the pc emit a sound
when the limb went through a precise point of space. I'd like to
change this sound for a video sequence on the screen, and I don't know
anything in labview (some students made the first soft for me). Could
anyone help me and would like to try to do the job?
Tnahks in advance for your help that could help me finish my Phd...
JLM
(2,752 Views)
Are you still using 5.0?
If not, please find attached example and see if it's working (it uses MS Mediaplayer to show the AVI file).
To finish the job, some details may help ...
- are you using labview or just the executable created with lv5.0?
- you want that movie inside a specific front panel or could be independent
- the code where the sound was triggered or a screen capture of its block diagram
(2,752 Views)
Sounds like its very doable.
Email me with details, and I'll see what I can do to help.
-Mike Du'Lyea
mdulyea@advancedtestengineering.com
(2,752 Views)
