a dial control with multiply digits
hi
i need in my VI a control of a number that can be increased by either 100,10,1,0.1,0.01 or 0.005.
is there a more elegant way of doing this than adding the 6 digits to a number (see attachment) in this way increasing 9 in one will not add 1 to the next digit.
thanks
amose
Message 1 of 13
(3,913 Views)
Hi amose,
You forgot the attachment! And would it help to set the scale to logarithmic?
Greets, Dave
Greets, Dave
Message 2 of 13
(3,901 Views)
Another method is to use an enum with the values you want typed in. Then connect the enum to a case structure where the actual values are stored and delivered to the program. With this method you can have arbitrary values: 0, pi, 46000, 1e9, -2, sqrt(11), ...
Lynn
Message 3 of 13
(3,893 Views)
And yet another method is to use a dial control with text labels.
Message 4 of 13
(3,888 Views)
see my question was not clear enough.
i want the possibility to increase or decrease the the value of the control in steps of one (either 100,10,1,0.1,0.01,0.05).
using the dial without typing the number. right now I have 6 control that are added to the final voltage. the problem is increasing 9 by 1 is not possible.
please have a look at the attachment (I hope it will be there this time)
amose
Message Edited by amose on 06-01-2006 01:49 AM
Message 5 of 13
(3,879 Views)
Amose!
How about this?
/Vedeja
Message 6 of 13
(3,871 Views)
sorry .Smiley Sad
I didn't convince my boss yet to upgradre my LV 6.1
please post a "print screen"
thanks
amose
Message 7 of 13
(3,866 Views)
thanks
I used an evalution version of LV 8 to vie your VI.
looks nice
amose
Message 8 of 13
(3,862 Views)
Stop Button is not working... need an event for it 😉 My apologies as this is not the main course... but side dish
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 9 of 13
(3,859 Views)
IFK!
You're right there is an event missing. I just put it in a while loop for demo purposes.
Never mind, I usually skip the side dish anyway... 😃
/Vedeja
Message 10 of 13
(3,847 Views)
