a question about VI server
Dear all,
I have some confusion about VI server. Suppose I
have two computers, computer A will be used as a client
and computer B will be used as server. A wants to get
access to a VI (test.vi) on computer B. What
requirements should computer B meet?
1). Run LabVIEW?
2). Run test.vi?
3). Run test.vi by open VI reference?
Does computer B should meet all the requirements?
Thanks a lot for your help!
Tao Song
Mechanical Engineering Dept.
Univ. of Maryland, Baltimore County
(3,466 Views)
Computer B has to be running LV or LV runtime and test.vi has to be loaded into memory and be executable (i.e. not broken).
From Computer A you first open a reference to the copy of LV running on Computer B. This means you have to know the name or IP address of Computer B, and the port number that LV is listening to for connections (which is configurable through the Options dialog box, or by editing Computer B's *.ini file directly).
Once you have the reference to the copy of LV, you open a reference to the remote VI (test.vi) by name with a type specifier defining the structure of test.vi's connector pane.
Connect this VI reference to a Call by Reference Node and you can run the remote VI.
Be sure to close all the references when you are done with t
hem as this can cause a major memory leak...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,466 Views)
Dear Mike,
Thanks a lot for your help! I think I understand it
now. Unlike the datasocket which has a separate server
program, for VI server LabVIEW itself works as a
server so it has to be runnig to listen to a port. Am I right?
But I still have doubt that if test.vi has to be loaded
into memory on computer B. If I use property and
method node on computer A, such as FP Open and Run VI,
can I remotely control computer B to load test.vi into memeory
and run it?
Thanks a lot! I really appreciate your help!
Tao
"mikeporter" wrote in message
news:50650000000500000025D20000-1042324653000@exchange.ni.com...
> the remote VI.
> Be sure to close all the references when you are done with them as
> Mike...
(3,466 Views)
You are right. From computer A you can remotely load test.vi and run it on computer B. You have to provide the full path of test.vi, as seen from the B computer. If you provide the path "c:\test.vi" it is the drive c: of computer B where the VI Server is running.
LabVIEW, C'est LabVIEW
(3,466 Views)
Thanks a lot!
"Jean-Pierre Drolet" wrote in message
news:506500000005000000B2D20000-1042324653000@exchange.ni.com...
(3,466 Views)
