about VISA read
If I wrote different values to different registers by using VISA write. Then I connected a VISA read after the last VISA write. How can I know the read buffer returned is from which register?
(3,728 Views)
What you read is totally dependent on the instrument itself. You have not provided the make and model of the instrument so how can you expect anyone to provide an answer? Have you studied the programming manual?
(3,718 Views)
this is the capture:
the instrument is Emcore TTX 1994, and the application note is attached. I only want to read the value from a certain register, but there are many VISA writes concatenated before VISA read, so I don't know which value is returned from VISA read.
(3,709 Views)
(3,689 Views)
continuation of what? you mean I should continue post in there, or they have the same answer?
(3,684 Views)
In my opinion, you should have continued there.
(3,661 Views)
