about horizontal and vertical scroll bar
Dear Friends
there is only horizontal and vertical scroll bar in labview. how can i move scroll bar at any angle ?
Asif
Message 1 of 8
(8,721 Views)
Hi Asif,
Most applications only have a horizontal or vertical scroll bar, so it sounds very unintuitive to scroll at some other angle. That being said, if you're going to be the main user of the application and you're really convinced this is a feature you want, you can use position properties of the front panel like so:
Message 2 of 8
(8,700 Views)
Accepted by JÞB
Asif138 wrote:  how can i move scroll bar at any angle ?
Rotate your monitor screen to the desired angle and then just scroll away.
Message 3 of 8
(8,668 Views)
Hey,
I don't think that functionality is built into LabVIEW's current builds.
But, if you'd like to put it out as an idea on the Idea Exchange feel free to post it to the forums there and maybe it'll be included in the future builds.
Idea Exchange - Discussion Forums - National Instruments - NI Forums
http://forums.ni.com/t5/Idea-Exchange/ct-p/ideas
Message 4 of 8
(8,631 Views)
Yes, I abused my powers!  I HAD TOO mark that solution!
Message 5 of 8
(8,590 Views)
If you're in development mode you can ctrl+shift+drag in empty space to pan the screen.  Perhaps that's what you mean by scroll any angle?
Tim Elsey
Certified LabVIEW Architect
Message 6 of 8
(8,448 Views)
A Picture control will let you do that!
Of course there will  a bit a coding to back it up and make it work but it could be done.
Ben
Message 7 of 8
(8,424 Views)
Accepted by Asif138
Borrowed example code Christian developed and posted here
All you have to do is add is to translate the mouse down/up on the pictue control using trig, do a Value change event to the scroll bar and you are done.
Ben
Message 8 of 8
(8,415 Views)
