about inverse FFT(IFFT) method
Thank you for always answering my questions. This time, please tell me how to convert IFFT after processing with FFT. If possible, it would be helpful if you could add it from the attached vi file. Thank you for your understanding.
(946 Views)
First I would recommend to read some lectures about FFT and IFFT ...
You need to know (or keep) the bins magnitude and phase ..  usually provided as a complex value in the basic FFT vi .. see math libs not the SVA libs 😉  and there you also find the IFFT vi 😄
Greetings from Germany
Henrik
LV since v3.1
(902 Views)
