lab view experiment
Please provide me the solution for
               Invert the state of boolean indicator twice a see until program stopped by user
(2,210 Views)
Hi mukundvc,
Why should we? (This is homework, isn't it!?)
Why don't you show your VI so we can comment on it and provide recommendations?
(2,202 Views)
See if it is correct?
(2,195 Views)
vi enclosed , is it correct?
(2,192 Views)
Hi mukundvc,
first lesson: not all of us use the most recent LabVIEW version(s).
So you reach more people when you downconvert your VIs (File->Save for previous) before attaching.
LabVIEW versions of LV2021 or older are most often fine, I prefer LV2019…
(2,183 Views)
Your requirement is to toggle a Boolean 2 times/second.
1. Your loop is running a 1 iteration/second, which is too slow for your requirement.  Change the wait time to 500ms.
2. You have too many controls here.  Based on your initial post, you should only have a stop button and the indicator.  Initialize the Shift Register with a False Constant.
3. Think about the data you want stored in the shift register.  I will just tell you that you are storing the wrong data.
(2,118 Views)
