about the numbers in indicators
Hi all.
I got another problem. When I set the osilliscope to measure, it seems
fine during the loop. But when the loop is done, all the indicators
become 999999999 or things like that. I wonder why the correct data
doesn't appear or stay there?
thanks!
redoo
(2,428 Views)
redoo,
Please post more information on this issue. (What oscilliscope are you using? Are you using GPIB? What is your loop doing? Are you using an instrument driver? What version of LabVIEW are you using? Have you done probing and debugging to see if you can find out where the values are changing?)
Randy Hoskin
http://www.ni.com/ask
(2,428 Views)
