about this VBScript
Hai to all,
i have some dobuts,
Call Main
Function Main
dim oLv ' LV application Objekt
dim oVI ' VI Objekt
dim sVIPath ' Pfad des VIs
dim sIONames(3) ' Namen der VI Bedien- und Anzeiegelemente
dim sIOValues(3) ' Werte der VI Bedien- und Anzeiegelemente
sVIPath = "D:\LabVIEW_VBScript\VBS_VI\mathe.vi"
' Eingänge des VIs
sIONames(0) = "Numeric"
sIONames(1) = "Numeric 2"
' Ausgänge des VIs
sIONames(2) = "Summe"
sIONames(3) = "Produkt"
' Werte an die Eingänge übergeben
sIOValues(0) = "2"
sIOValues(1) = "10"
' LabVIEW öffnen
set oLV = CreateObject("LabVIEW.Application")
' eine Referenz auf das VI holen
' object.GetVIReference(viPath,
[password, resvForCall, options])
set oVI = oLV.GetVIReference(sVIPath)
msgbox "VI Statring"
' VI starten
' object.Call2([paramName, paramVals, openFP, closeFPAfterCall, suspendOnCall])
call oVI.Call2(sIONames, sIOValues, true, true)
' Ergebnisse anzeigen
msgbox sIONames(2)&" : "&sIOValues(2)&vbcrlf&sIONames(3)&" : "&sIOValues(3)
End function
in this function i getting some function
"set oVI = oLV.GetVIReference(sVIPath)"
what is "GetVIreference" it is VBScript Reserve Word or, LabVIEW Word.
"call oVI.Call2(sIONames, sIOValues, true, true)"
in that also Call2?
I am confusing what is two function?
please give the your valable answers.
if you want you can download this complete document. Here i am attaching in zip format, ie. Script and VI
(2,761 Views)
srq: 204233
hello,
"GetVIReference()" is a method of LabVIEW ActiveX.
It returns a reference to a LabVIEW-VI;
The VI object oVI has several methods;
one of these methods is "call2" which calls the VI and you can pass some parameters to it, as mentioned in the comment.
If you browse the LabVIEW help and search for "ActiveX, VI class methods", you will find further information.
regards,
Robert H.
(2,761 Views)
