Hi all,
Using a PXI-8176 controller, I more than often get a "reference memory could not be read" or "Labview memory is full" message when communicating to a ATC-SCC serial card (Transmit line looped back to Recieve line) through a third party DLL that runs well on its own.
This message usually occurs when I have the call DLL function node in a continuous loop but is not consistent as to which loop iteration it occurs in. It seems to happen when a Recieve request is made.
I have configured the call library node to Re-entrant. The DLL is specified to autosize the associated FIFO buffers but at this stage of development I am transmitting small amounts of data (18 - 1
80byte strings) before performing the Recieve operation which sometimes works OK.
Using Labview7 on Win2000 OS the task manager indicates memory usage of 135Mb with the program running. I am soon upgrading from 128Mb to 256Mb SDRAM but have my doubts if it will work since I tried increasing virtual/shadow memory to 300Mb (task manager then shows usage at 135Mb/300Mb).
The serial card is an Alphi Techology Corporation product; Quad channel Serial Comms Controller supproting RS232/422/485.
I have also read the discussion thread from Frenk (03/18/2004) - I suspect the DLL I use does not perform a CLEAR operation after its calling subvi finishes executing. Is this of significant impact??
Any advice please?
Many thanks in advance.
Kenos
